2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Antifreeze drain
Old Jun 19, 2019 | 11:41 PM
300Guy's Avatar
300Guy
Default Antifreeze drain
Does anyone know where the drain on the block of a 2012 Avenger 4 cylinder engine is located? I have to change the antifreeze this next month and would like to know where to look for the drain. I have not looked for it yet, but it helps to know where to look when you jack it up. Thanks everyone!!!
Old Jun 20, 2019 | 07:28 AM
You can drain it from the radiator. There is no drain on the block.
Old Jul 1, 2019 | 09:58 PM
lxman1's Avatar
lxman1
Site Moderator
I don't know of a drain in the block, when I did my niece's 09 a few weeks ago, I just removed the air filter box and pulled the lower hose off of the radiator and drained the system. The radiator drain is inaccessible unless you are contortionist..
