2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
ABS problem
Old Jun 27, 2019 | 09:25 AM
Jags71's Avatar
Jags71
Default ABS problem
Hello I have a 2012 dodge avenger, ABS light came on and ran test, said short in right front. Replaced the sensor and then checked the hub, found out magnetic ring was partly missing. Replaced the entire hub and seemed to be ok. Now ABS system kicked on every once and awhile. Wondering if I have to reset the computer on the car to reset everything or what else can be the problem? Thanks!
Old Jul 1, 2019 | 10:09 PM
lxman1's Avatar
lxman1
Site Moderator
You could try unhooking the battery for about an hour to reset the whole system. it's free and worth a shot.
