2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Clicking behind glove box.
Old Jul 2, 2019 | 10:20 PM
gasman_66's Avatar
gasman_66
Default Clicking behind glove box.
2010 Avenger. Started out only happening when 1st started. Now it does it once in a while during driving. Is there a relay behind the glove box?
Old Jul 3, 2019 | 07:56 AM
Most likely the HVAC blend doors moving around. Or, one of the actuators is stripped.
Old Jul 8, 2022 | 11:12 PM
NissNiss's Avatar
NissNiss
Default Glove box clicking
Yes iy is in fact behind the glove box and it is the vent actuator or blend door it switches from hot to cold air and is getting stuck . If it is let go it will stop making noise for awhile . But it will eventually cause hit air to blow out the driver side vents and cold air to blow out the passenger vents.
