2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2010 Avenger Blower Motor not Working
Old Jul 8, 2022 | 02:40 PM
dowatt's Avatar
dowatt
Default 2010 Avenger Blower Motor not Working
Hi,
My daughters 2010 Avenger RT's blower motor does not work. I replaced the blower motor resistor, bench tested the blower motor and checked fuse #22 and all good. I can hear the AC compressor kick on and the control **** lights up but the blower does not bow any air out of the vents. Could it be the HVAC control head or something else I've overlooked?
Thank you in advance!
Old Jul 15, 2022 | 01:11 AM
master tech's Avatar
master tech
Site Moderator & Tech
Can you get a test lite and check the circuit to see if you have power or ground to the motor by switch the **** on the control head?
