2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2008 Dodge Avenger Se (2.4 Liter) Loud Noise from Engine
Old Jul 30, 2019 | 11:09 AM
guapoman2000's Avatar
guapoman2000
Thumbs up 2008 Dodge Avenger Se (2.4 Liter) Loud Noise from Engine
Hello good people!
It's been a while since I posted and last time I posted was about my daughter's 2008 Dodge Avenger SE (2.4Liter) intake manifold replacement at 88,000 miles.
Today I like to share a very good experience with one certain PARK's Dodge Chrysler Jeep Dealership located in Titusville, Florida. About four days ago the same daughter's 2008 Dodge Avenger SE (2.4L) developed a loud noise once warmed up and it sounded like a train going through a tunnel. At higher RPMs you could NOT hear this sound but, at idle at the stop light you could.
I never thought to remove the decorative plastic TOP cover of the 2.4 Liter Engine (my fault) and decided to take it to the dealer who replaced the Intake Manifold thinking it was something associated with that work. Needless to say I was embarrassed when the Service Writer and Mechanic followed me to the parking lot and they took off the Plastic Decorative Engine Cover to find plain as day the PVC inlet hose was collapsing on itself and which was causing the noise.
The mechanic went at least three times in-and-out of the shop and finally found a suitable PVC inlet hose replacement. With a little lube spray he installed the newer hose and it was a perfect fit plus it was thicker than the stock as this one will NOT collapse on itself! He told me that if they attempted to order this little STOCK PVC hose it would come with the entire plastic tube that goes behind the intake manifold so, he saved me lots of $$$.
I was already thinking of a large repair bill such as the ADP (Alternator Decoupler Pulley) but, this time it was NO CHARGE!
A few pictures! Sorry no Video!
Old Feb 11, 2021 | 03:43 PM
guapoman2000
Hello good people!
Okay a QUESTION:
Anyone can tell me with certainty that the 2.4 Liter Gasoline Engine (2008) takes a while for the Oil Pressure to get at a point for good lubrication?
I ask because every morning during COLD start it makes a low rumbling sound and after perhaps 25 seconds it goes away!
Anyone?
Old Feb 12, 2021 | 12:16 AM
guapoman2000
Oil change done!
Present Odometer reading: 105,520 original miles.
Previous Odometer reading: 98,085
7,435 Total Miles
What a difference a new Air Filter Makes!
Mopar all the way, baby!
Using the same Oil since the car was new!
Old Feb 12, 2021 | 08:00 AM
guapoman2000
Originally Posted by guapoman2000
Hello good people!
Okay a QUESTION:
Anyone?
UPDATE:
The Engine has the sound for only 5 seconds during COLD START and then, all is normal.
I guess nothing to worry about.
Keep on going!
