2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2013 over heating/ head gasket 2.4
Old Oct 12, 2019 | 11:18 PM
philco90's Avatar
philco90
Default 2013 over heating/ head gasket 2.4
I will try to make a long story short . Ok I have had my car back to the dealer ship 5 times for this after the second time I have suspected the heat gasket. well they pressure checked replaced the radiator cap. well coolant disappeared aging and I noticed the when it got to running temp coolant went to the over flow but did not return. This tells me there is a leak in the system some where. so next they replaced the thermostat well that did not fix it and coolant still losing it some where I also told them that I was not hearing the high blower kick in but only when the ac is on . then it started missing on number there cylinder well now trip five they pulled the head and told me the block deck is warped and so is the head and the engine is toast. Thankfully its still on a Chrysler warranty I have looked on line and it looks like there is an updated head gasket for this I wonder if they would have done a block check could all this have been prevent and is this a common problem
benny
Old Oct 17, 2019 | 10:28 AM
DodgeCares's Avatar
DodgeCares
Hi @philco90,
We're sorry to hear this has happened! If you would like additional support while you are in service, please send our team a private message with your VIN, mileage, and dealer.
Darlene
Dodge Cares
Old Oct 17, 2019 | 10:46 AM
philco90's Avatar
philco90
Default Hello
Originally Posted by DodgeCares
Hi @philco90,
Darlene
Dodge Cares
How do I send you a private message
Old Oct 17, 2019 | 01:23 PM
DodgeCares's Avatar
DodgeCares
@philco90,
Click on our name and then select "Send a message to DodgeCares."
Darlene
Dodge Cares
Old Oct 21, 2019 | 10:21 PM
lxman1's Avatar
lxman1
Site Moderator
Unfortunately, some dealers are not as good as they should be. At least they are making right now!!
Old Oct 21, 2019 | 10:51 PM
philco90's Avatar
philco90
Default Overheating
Overheating my concern is is this something I have to worry about is this a one time deal or is this an issue for this model of car
