2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2013 Avenger Brakes
Old Feb 24, 2020 | 07:04 PM
johnel61's Avatar
johnel61
Default 2013 Avenger Brakes
Any ideas if the master brake cylinder could be failing or stuck caliper piston? Step on brakes and car stops fine. Sometimes there is an additional grab that feels like a pulse but it is after complete stop. Pedal seems a little softer than it should. I'm thinking ABS too but no codes or messages.
Old Feb 25, 2020 | 11:09 AM
DodgeCares's Avatar
DodgeCares
Hi johnel61, We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist. If you do work with your dealer, we would be more than happy to provide you with additional support.
Rob
DodgeCares
