2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
2010 Dodge Avenger Low Power
Old Feb 1, 2022 | 09:12 PM
spirittoo's Avatar
spirittoo
Exclamation 2010 Dodge Avenger Low Power
Not only is this avenger running rough at times could be due to misfiring cylinder I'm getting a PO 304 reading. But the main problem is the electrical icon is flashing when I start the car. When it is flashing the car won't go over 30 with only 2500 rpm. To get the icon to stop flashing I have to turn of the car and restart it, but only after I has been running for a few minutes. After that I get the power back. I know the alternator is functioning because I am getting 14.7 volt reading from the battery and with the mysterious battery drain that no one can figure out the alternator must be working. .
Does anyone have any idea what this could be?
Thanks for reading my post.
Old Feb 5, 2022 | 02:51 PM
master tech's Avatar
master tech
Site Moderator & Tech
Do you mean the lighting bolt on the dash?
Old Feb 5, 2022 | 07:37 PM
spirittoo's Avatar
spirittoo
Yes. I thought a dirty throttle body was the problem. I cleaned it and it got rid of the of the lighting bolt icon I thought, but it started again. I'm thinking of replacing the throttle body and for the missing I'm going to try to replace the spark plugs.
Old Feb 19, 2022 | 04:52 PM
spirittoo's Avatar
spirittoo
Wellsir ... I had the throttle body and the spark plugs replace and there was absolutely no change at all. $160 for parts and labor down the drain. I have given this car a name ... Christine ... from the Steven King movie ... and Enigma .... like puaaling ... Christine Enigma ... ffits her perfectly.
I only get the flashing electric icon when it is below freezing ... when it is warmer it doesn't come on. When it does come on I have to wait for the engine to get completely warm so I can turn it off and on again to get it to stop so I can go faster than 30 mph.
She acts like she is running on 3 cylinders sometimes at certain speeds but she will smooth out and run okay sometimes.
