2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
View Poll Results: do you drive with od on or off
od on
66.67%
od off
33.33%
Voters: 15. You may not vote on this poll
driving with od off
Old Sep 10, 2010 | 01:13 AM
  #61
magnethead's Avatar
magnethead
Originally Posted by dodgeramguy85
Quick question for you guys I need a 7 pin wiring harness for cheap any good places to get it from? I have a brake controller but I have no idea if it works anyway to tell without a trailer hooked up? Need to know bought a 20foot double axle trailer for 350.00 needs wheel bearings and boards replaced other than that this thing is in good shape has newer trailer brakes. Ill get a pic of it when I get it.
If my understannding is right, you should be able to apply 12 volts to the brake trigger wire (what would normally go to the brake light switch?) as well as the main power wire, and get a voltage output from the trailer wire. Then unhook the brake switch wire and use the manual activator, and should also get an output.
I think?
Old Sep 10, 2010 | 09:49 AM
  #62
Rantz's Avatar
Rantz
walmart should have the 7 pin harness
Old Sep 16, 2010 | 05:19 PM
  #63
#DodgeFan#'s Avatar
#DodgeFan#
having just recently gotten mine havent had the opportunity to try this. most of my driving is on the interstate anyway, but i'll remember to do this on my next in-town trip
