2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
View Poll Results: do you drive with od on or off
od on
66.67%
od off
33.33%
Voters: 15. You may not vote on this poll
driving with od off
Old Aug 24, 2010 | 02:00 PM
thunder98110's Avatar
thunder98110
Default driving with od off
i found that driving with od off my truck feels much better. throttle response is way better than od on. in the city atleast. what do you guys prefer? driving at 50mph rpms are at like 2 grand vs just over 1k. so when you punch it there no lag. plus it sounds epic when you back off the throttle and it uses some engine braking.
Old Aug 24, 2010 | 03:12 PM
twitchy's Avatar
twitchy
I'm partial (due to forgetting to disengage it) to leaving the O/D on always.
it starts up automatically when I turn over the ignition and I neglect to turn it off.
Ultimately it's my understanding that in the city there's really no need for it to be enabled, since you're rarely over 65km/h (40mph)
The response with O/D off is great, and I really should disengage it more often, since I'm usually between 25 - 40 mph on my way to / from work daily.
Old Aug 24, 2010 | 08:21 PM
SpencerS's Avatar
SpencerS
I drive everywhere with OD off pretty much except when i hop on the highway. Less shifting=better gas mileage. at least ive gotten a 3 mpg diff.
Old Aug 24, 2010 | 08:32 PM
thunder98110
yea also keeps the tranny cooler. but i love the throttle response so i always have my foot to the floor. probably -3 for me.
Old Aug 25, 2010 | 03:31 PM
Rantz's Avatar
Rantz
I always forget to turn it off when I'm in town. I'm going to make an effort to start doing this
Old Aug 25, 2010 | 04:58 PM
FireFighterHill's Avatar
FireFighterHill
What is the highest MPH one should drive with O/D Off? My truck when pulling a lawn (1,600 pounds) trailer barely stays in O/D unless im going down hill. Would it hurt the tranny to drive at 65mph with o/d off for extended periods? I ask because I need to go pick up a generator trailer that weighs 2,100 pounds in GA and it will be 300 miles there and 300 miles back pulling the trailer on I-75.
Old Aug 25, 2010 | 05:08 PM
Hahns5.2's Avatar
Hahns5.2
No it wont hurt it. It will actually be better for it to keep it out of OD when towing and at low speeds, theres no need for RPMs to be below around 1700 when cruising, you're likely to use more gas doing this because you're lugging the engine.
Old Aug 25, 2010 | 05:13 PM
Rantz's Avatar
Rantz
You will burn up your transmission if you tow with Overdrive turned ON. Whenever you tow anything past a couple of passengers in your cab, you should turn overdrive OFF.
Old Aug 25, 2010 | 05:26 PM
FireFighterHill
What about driving at high speed for extended periods with O/D off? As I said I have planned a 6 hour 300 mile trip towing 2,100 pounds and It would be nice to drive the speed limit of 65mph. Is 65mph to fast to drive with o/d off?
Old Aug 25, 2010 | 06:14 PM
thunder98110
u will burn through gas faster b.c you will be at like 2,5k rpms. but i dont think it will hurt the tranny.
