2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
Advice on inexpensive way to either add dual exhaust or better sounding exhauat
Old Mar 7, 2012 | 08:03 AM
liam5340's Avatar
liam5340
Default Advice on inexpensive way to either add dual exhaust or better sounding exhauat
Any info on how to turn single exhaust into a good sounding dual exhaust or just a good single exhaust that will sound a little meaner than stock for the least amount of money? I got an 02 quad can v6 4x4
Old Mar 8, 2012 | 01:33 AM
fhadso's Avatar
fhadso
Just pickup a cherrybomb turbo at AutoZone. It's cheap, and it does make it sound a little meaner without making it annoyingly loud. Makes it sound like what a truck should sound like.
Old Mar 8, 2012 | 07:37 AM
liam5340's Avatar
liam5340
What do I need
To
Buy with it? Just so I got everything I need and don't have to drive back to parts store in the middle of job. Thanks.
Old Mar 8, 2012 | 06:49 PM
fhadso's Avatar
fhadso
Just the muffler. Take it to a local auto repair shop and they can install it for you for cheap. Make sure you get the offset and measurements of the inlet and outlet pipes.
Old Mar 8, 2012 | 08:03 PM
liam5340's Avatar
liam5340
What should the measurements be and offset? Also is it a hard job to do? Do I need to take it to a shop?
Old Mar 9, 2012 | 04:40 PM
fhadso's Avatar
fhadso
Just take it to a shop. It's technically a fairly easy job but it would save you personally time and money to take it to a shop. The measurements are different from model to model. I have a 1999 SLT 3.9L V6, and mine are 2.25" and has the opposite offset, inlet and outlet are on the right and left side. If you took it to a shop, they could find out for you.
Old Apr 22, 2012 | 09:21 AM
Muddking's Avatar
Muddking
Muffler shop sold me a flow master 44 for $220 installed.
Old Apr 22, 2012 | 03:33 PM
Johnn123's Avatar
Johnn123
I installed a cherry bomb glass pack myself for $70 installed. You will need to measure the diameter of the muffler outlets, you exhaust pipe ( should be 2.5"), what adapters you will need and how much tail pipe you want.
