2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
AC Clutch Problems
Old May 11, 2012 | 08:43 PM
00DakDan's Avatar
00DakDan
Section Moderator
I'm also starting to think you may have a restriction in your fixed orifice tube, not much of one, but just enough.
Old May 11, 2012 | 08:49 PM
vunillag0rilla's Avatar
vunillag0rilla
Well now I turned off the truck n let it sit it doesn't engage the clutch on the compressor anymore, back to the paper clip, fml.
Old May 11, 2012 | 10:08 PM
00DakDan's Avatar
00DakDan
Section Moderator
What are the pressures doing now?
Did the system work correctly before you replaced the coil?
Old May 11, 2012 | 10:32 PM
vunillag0rilla
I not at my shop to test the pressures but to answer your question, I bought the truck used n the dude said all it needed was to be recharged, yeah bs the coil wasn't in the omhs range for being good and they system had a little but of a charge in it so.
Old May 12, 2012 | 12:26 PM
98DAKAZ's Avatar
98DAKAZ
Exclamation Where are you in AZ
Where are you in AZ I’m in Gilbert, AZ and have been doing my A/C myself I’m no pro but I understand what’s going on and have rebuilt my A/C.
Your problem sounds weird but in person I may get it fixed.
If close come on over and we can get this figured out if you want I’m around the 202 and Gilbert Rd If you wish to contact me personally go here. http://www.rp95.com/connt.html
It may be the orifice tube when I did my A/C the first time it was black and gunked up bad surprised I had any A/C at all what pisses me off is a shop worked on my A/C for 5 months and I got nothing fixed by these rip off crooks that is why I started doing my own A/C work.
I can come to you possibly if needed.
Old May 12, 2012 | 12:46 PM
98DAKAZ's Avatar
98DAKAZ
Default One other thing
One other thing if the previous owner had it apart moisture got into the system this could be what’s going on also the A/C Receiver Drier/Accumulator may need replacing its shot every time the A/C system is apart you should replace the A/C Receiver Drier/Accumulator that is what removes the moisture.
Old May 12, 2012 | 01:20 PM
98DAKAZ's Avatar
98DAKAZ
Default I dont use text
I dont use text messages my friend sorry you must send me an email address if you wish to contact me.
