Brake Fluid leaking from rear driver side, I noticed fluid on tire/rim
Noticed fluid on inner tire when I looked under there after my brake light went on and fluid was low, is it the cylinder? How to fix??
It very well could be a wheel cylinder. Fortunately they're cheap but you'll end up replacing the brake shoes (on both sides) too as they'll be contaminated.
Should be two bolts and the brake line. The brake line is usually the worst part as it is often corroded. Put some penetrating oil on it and let it soak overnight first.
You'll need a partner to bleed the brakes.
My left rear cylinder has been leaking as well. If I have anything left of this paycheck, that's where it'll be going. Prob oughta check fluid level....been leaking for at least a year and change.....
