2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
2004 Dodge Dakota 4x4 Radiator drain plug..
Old Jun 13, 2014 | 10:40 PM
jimmyjamestx's Avatar
jimmyjamestx
Default 2004 Dodge Dakota 4x4 Radiator drain plug..
So, I was attempting to flush my radiator when I turned the drain plug 1/4 of a turn counter clock wise and the turn **** broke. It's not leaking. It was really in there tight. Is this a problem ? I let it run for around 20 minutes til it heated up and no leaking.
Old Jun 14, 2014 | 11:00 AM
00DakDan's Avatar
00DakDan
Section Moderator
As long as it isn't leaking you'll be fine. Keep an eye on it the next few days just to make sure.
I usually use one of those prestone flush kits. It's a lot easier than dealing with the drain.
Old Jul 7, 2014 | 10:02 PM
magnethead's Avatar
magnethead
Mine did the same thing. I just yanked the lower hose off the water pump. Makes a mess, but gets the job done.
Old Jul 8, 2014 | 01:27 AM
archemedes74's Avatar
archemedes74
yep had that happen on many cars, my own stuff I do the hose, customers I fight it and replace it (and charge them of course lol)
