2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
take bed off for maintenance
Old 07-25-2014, 01:04 PM
LIZZRD's Avatar
LIZZRD
LIZZRD is offline
Default take bed off for maintenance
After getting the rear sway bar bushings and end links, during install i looked at those old rusty leaf spring shackles and rusted clamps and am really considering taking off the bed. ( spent it's first 12 years in Illinois = rust) It sounds like it is a fairly easy job with a couple guys needed to lift off. Not really sure what to put on jack stands or support as far as axle, frame, spring. That way i can spray penetrating oil and get a good hold on the bolts/nuts. Plan on using a angle grinder for any stubborn bolts and to grind off/ wire brush rust, then some Rustoleum. I should also take the bumper off, some rust. Rather not rattle can that so considering paying someone to sand or blast then powder coat. About how much $ should i expect for that ?
Since i am there, replace the fuel pump/filter.
should i replace 7 year old Monroe reflex shocks ?, not hard miles...
Any suggestions from experiences ? , thanks
Old 07-26-2014, 11:55 AM
sxrsil3nt's Avatar
sxrsil3nt
sxrsil3nt is offline
This was just discussed not to long ago actually, here you go:
https://dodgeforum.com/forum/2nd-gen...oving-bed.html
Quick Reply: take bed off for maintenance
