2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
Build sheet back, explain.
Old Dec 19, 2014 | 11:20 PM
dormsauce's Avatar
dormsauce
Default Build sheet back, explain.
Does this mean i have the upgraded sports package? Not sure if ive read enough on the Dakota to understand the build sheet fully lol.
Build sheet:
Vehicle Description: DAKOTA P/U CLUB
Model Year: 2002
Sales Code Description
P9 Cloth 40/20/40 Split Bench Seat
DV Dark Slate Gray
ADAS Light Group
ADJ Heavy Duty Service Group
AGBP Tire and Handling Group
AGUP Sport Plus Group
AHC Trailer Tow Group
AJKP Deluxe Convenience Group
AJPP Power Convenience Group
APAS Monotone Paint
A29P 4.7L Engine(EVA)/4Spd A/T 45RFE(DG4)
BAZP 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
BKES 9x2.5 HD Rear Drum Brakes
CBEP 40/20/40 Split Bench Seat
CBPP Cloth Door Trim Panel w/Map Pocket
CCAS Rear Fold Under Seat Storage
CGWS Next Generation Front Air Bags
CGZS Passenger Air Bag On/Off Switch
CKES Front Seat Area Carpet
CLAP Front Floor Mats
CSRS Passenger Assist Handle
CSWS Driver Assist Handle
CUDP Mini Overhead Console
DGBS All 4-Speed Automatic Transmissions
DG4 Multi-Speed Auto 45RFE Transmission
DHAP Lock-Up Torque Converter
DHTS Elec,Shift-on-the-Fly,P/Time T/Case
DJDS 205MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
EVA 4.7L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror
GNDS Driver Side Sun Visor
GNES Passenger Side Sun Visor w/Mirror
GTS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXRP Keyless Entry
HAAS Air Conditioning
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Power Outlet Mounted in IP
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
KNXS BLACK - BADGE - DAKOTA, FRONT DOOR
KRXS BLACK - BADGE - 4 x 4, TAILGATE
KSXS BLACK - BADGE - SPORT, FRT DOOR
KTXS BLACK - BADGE - DODGE, TAILGATE
K2WP BRIGHT WHITE CLEAR COAT - WHEELFLARE
LBCP Glove Box Lamp
LCDP Map/Dome Reading Lamps
LMBS Halogen Headlamps
LNJP Fog Lamps
LPEP Cargo Lamp
LPSS CHMSL Lamp
MBAS Body Color/Black Front Fascia
MBDS Body Color/Black Rear Bumper
MDAP Front License Plate Bracket
MFNS Body Color Grille
MHAS Black Windshield Moldings
MLAS Body Color Fascias
NAS 50 State Emissions
NBKS EVAP Control System
NBVP Low Emission Vehicle (LEV)
NFBS 22 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHFP Power Steering Cooler
NHMP Speed Control
NMCP Heavy Duty Engine Cooling
PW7 Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RBKP AM/FM Compact Disc Radio w/Chgr Ctrl
RCDS 4 Speakers
RDDS Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHCP Rear Stabilizer Bar
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TXVP P265/70R16 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WD1P 16X8.0 Cast Aluminum Wheels
WLBS Steel Spare Wheel
XBSS Pickup Box
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFLP 7 to 4 Pin Wiring Adaptor
XSLS Brake/Park Interlock
YAAS Build To U.S. Mkt. Specifications
