2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
I need to lower a 2002 Dodge Dakota that has been lifted
Old Nov 26, 2018 | 11:23 AM
rdj48's Avatar
rdj48
Default I need to lower a 2002 Dodge Dakota that has been lifted
I have a 2002 Dodge Dakota 4x4 that has been lifted. I looked under the truck and I can see that a body lift kit was used but I’m not sure about the front end. How high can the front be lifted with the torsion bar? Can a after market bar be used to raise it higher?
Old Nov 26, 2018 | 12:12 PM
You can only get 2 or 3 inches out of the torsion bars, before you start running into other problems. Mainly, ball joint angles...... (not to mention CV shaft angles.....) What size tires are on it? And why do you want to remove the lift?
Old Nov 26, 2018 | 03:34 PM
rdj48's Avatar
rdj48
Default Tire size
Tire size: 315/75-R16
I need to lower it because of our age. We can hardly get up in it but it also makes for a rougher ride. Steering is worse because the tie rod ends are at an angle.
Old Nov 26, 2018 | 04:46 PM
Those aren't gonna fit if you take out the lift.......
