2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
Uneven control arm height?
Old Apr 10, 2020 | 10:48 PM
StevenH's Avatar
StevenH
Default Uneven control arm height?
2000 Dakota 4x4. Recently changed upper control arms and shocks on both sides. I was trying to make some adjustments for camber and castor, and although I got pretty close to spec., I noticed that the driver's side upper CA is almost a half inch closer to the bump stop than the passenger side, it's actually touching it I checked the ride height on a level surface and the distance from the lower CA bolt to the ground is the same on both sides. How could this be? Nothing looked bent. I could really use some help on this one cuz I just don't get it. Thanks.
Old Apr 11, 2020 | 12:53 PM
primem's Avatar
primem
spring sag would be my guess
