2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
Replacing Clutch Fluid
Old May 26, 2021 | 01:27 AM
olDakota's Avatar
olDakota
Default Replacing Clutch Fluid
I have an '01 Dakota with a 5 speed manual. I'm trying to find out if the clutch fluid can be bled and replaced. The local Dodge dealer said it's sealed. A couple threads here seem to confirm it, but Is this end of story or are there options?
Thanks for any help.
Jim
Old May 26, 2021 | 07:32 AM
See if there is a bleeder valve on the slave cylinder. My guess is, there isn't... which makes the exercise quite difficult. I believe the slave/master/line are replace as one unit in the event it fails.....
Old May 27, 2021 | 07:55 PM
olDakota's Avatar
olDakota
I'm not a mechanic and wouldn't know where to look, but I have an appt with one who said they would flush it. From what I've read, everything points to what you said, that it's a sealed system and everything is replaced as a unit. So I'm guessing the mechanic either doesn't know about the sealed system or taking me for a ride.
Thanks.
Old May 28, 2021 | 07:34 AM
Yeah, use a turkey baster to suck out the old fluid from the master, refill with fresh, and call it a 'flush'...... Seen that happen before.
Slave cylinder is down on the trans. You can follow the line from the master, down to it. If there is a bleeder valve on it, it's flushable. If there ain't, it ain't.
