2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
2000 Dakota 3.9 Cranks but not starting
Old Dec 6, 2021 | 05:04 PM
Sal D's Avatar
Sal D
Default 2000 Dakota 3.9 Cranks but not starting
Just today!!
I changed the water pump on this truck, about a 4-hour job. Got in and tried to start it. It would crank and crank but would not start. I am out of reasons why it won't start.
Any and all help is appreciated by this old man!!
(A little extra. I actually changed the water pump 3 days ago. Filled it up with coolant and water. Three minutes later it was leaking from a bolt. Tried tightening it, but no help. Bought another gasket. And the story above is where I am.)
Old Dec 6, 2021 | 09:04 PM
There are a couple of fat ground wires that bolt to the engine, make sure that they are indeed grounded, and have a clean, tight connection. I *think* there are a couple that go to one of the bolts for the bracket the power steering pump is in.
Old Feb 7, 2023 | 03:33 AM
WOODY WOODS's Avatar
WOODY WOODS
3 things for a motor to run, fire -fuel- compression.
Old Feb 7, 2023 | 03:38 AM
WOODY WOODS
Did you check the crank sensor right under the water pump?
