2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
"PCV elbow." Does this style crankcase vent have a valve?
Old Aug 6, 2022 | 04:33 PM
eddie25's Avatar
eddie25
Default "PCV elbow." Does this style crankcase vent have a valve?
I have the crankcase vent that's just the black thing that looks like a PCV valve and the parts places all call it a "PCV elbow".
See:
Dorman 47079"><span style=Dorman 47079" /> Dorman 47079">Dorman 47079
Does this type have a valve in it? Do they get clogged?
It's my understanding it can be a much bigger pain to change than the PCV (which was a snap), so if it's just an open 90 degree tube I'm not gonna even bother.
Any reason to switch to the big ole metal breather style?
1999 Dakota 3.9L V6 RWD
Old Aug 9, 2022 | 04:22 PM
garilla's Avatar
garilla
Eddie
I have a 2003 3.9 RWD and that part on mine is on the passenger side rocker cover and is just a straight through tube. The PVC valve is on the drivers side rocker cover and has a hose that goes into the throttle body or intake I don't remember which. That part you show has a tube that goes into the air intake big 3inch tube and the air intake sucks air out from under the rocker cover into the intake of the throttle body. They sometimes can get all nasty inside with oil deposits but a cleaning will cure that just some wire with a rag should do same with the hose to the air intake. The plastic/rubber they are made from turns hard as rock and usually require you to break them out to put in a new one and of course pieces break off and fall inside. So if it isn't broken I'd just clean it.
Old Sep 3, 2022 | 09:07 PM
supadoom's Avatar
supadoom
Its the same on the 5.9 and 5.2 as well. Just a simple tube with no valve or anything. As long as its not broken or leaking just leave it be.
