2nd Gen Dakota general discussion This section is for general discussions about your 2nd gen Dakota. Non tech related Dakota threads belong here.
2001 4.7 trucks primary coil faults
Old Sep 6, 2025 | 01:45 PM
Originally Posted by Stevengates1
(NGK Spark plugs)
Copper plugs?
Old Sep 6, 2025 | 02:23 PM
dodgetruck2's Avatar
dodgetruck2
I'm not very familiar with the open/closed loop stuff with 02 sensors, but sounds like an issue when the ECM should be in idle mode, I know on diesels, the variable throttle system and idle system on the TPS are two different maps, controlled by the same sensor, it uses a certain voltage to trigger the idle fueling map vs above a certain voltage is uses the variable throttle map. I know the TPS was replaced, could be new faulty, or wiring, or maybe even PCM?
Old Sep 6, 2025 | 02:33 PM
Stevengates1's Avatar
Stevengates1
Copper plugs?
yes copper
Old Sep 6, 2025 | 04:59 PM
Did you swap out the PCM????
Old Sep 6, 2025 | 07:09 PM
Stevengates1
yes with the same issues .if you follow this thread back you will see everything I have tried or replaced
Old Sep 6, 2025 | 08:31 PM
Yeah, I saw that, but, wasn't sure that you actually swapped it, so I asked, just to be clear.
Does anything change if you disconnect the front O2 sensors?
Old Sep 6, 2025 | 09:33 PM
Stevengates1
no change have tried that as well.. I am just stumped..
Old Sep 7, 2025 | 08:16 AM
dodgetruck2
have you tested oil pressure at hot low idle, and hot high idle with a mechanical gauge?
Old Sep 7, 2025 | 09:27 AM
Not sure what the correlation there would be.......
Single plug per cylinder on this engine??
Old Sep 7, 2025 | 10:36 AM
Stevengates1
Yes around 25psi low and 41psi high
