Hmmmmmm....Power Steering Pump?
Old Apr 6, 2007 | 09:28 PM
sammyg429's Avatar
sammyg429
Default Hmmmmmm....Power Steering Pump?
My power steering pump was leaking, I'm not sure where at. I started to use brake fluid for a while, and the pump does not seem to work at all now. I'm thining the pump is shot. What steps and parts will I need to undertake this?
Old Apr 6, 2007 | 09:40 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: Hmmmmmm....Power Steering Pump?
you put brake fluid in the powersteering system? maybe that has something to do with it. I would atleast use tranny fluid, its better for it.
but it could either be your lines or your pump. how much does it leak?
and the pump is pretty easy to replace
Old Apr 6, 2007 | 09:47 PM
English_Dakota's Avatar
English_Dakota
brake fluid will have killed the pump completely.
you'll need a new pump, but you'll have to find out which pipes were leaking and swap them out too.
good luck.
Old Apr 7, 2007 | 12:53 AM
imnothot02's Avatar
imnothot02
common tools and sockets, new pump, P/S fluid get 2 quarts i duno how much you lost...what is this on?
Old Apr 9, 2007 | 08:23 PM
chris1974's Avatar
chris1974
yeah, deffinatly dont use brake fluid in power steering pump. If nothing else, and still dont understand reasoning behind it, use trans. fluid.
