Freakin' Crap.... brakes....
Old Apr 12, 2007 | 06:44 PM
emtsquad51's Avatar
emtsquad51
Default RE: Freakin' Crap.... brakes....
holy-freakin-crap! where did you price the knuckle from? I'm assuming straight from Dodge? I was going to go to a salvage yard to pick one up if I needed too.. I'm cheap.. haha have you had to take that bolt back out for any reason since you installed it? Just wondering if you can re-use it or not since the package warns not too.. but you know how those warnings go sometimes..
Old Apr 13, 2007 | 12:35 PM
300exoh's Avatar
300exoh
ORIGINAL: emtsquad51
From the Dodge dealer it was a bit over $600 and it was around $560 from an aftermarket auto parts store. I was searching the salvage yards for a used knuckle and apparently they are somewhat rare so I never got a price on one. I haven't had to remove the bolt so far but I'm guessing the threads on the bolt will stretch if re-used. If I have to take it apart again for any reason I'll probably replace the bolt with a new oversize one just to be safe.
Old Apr 13, 2007 | 12:42 PM
jk240sx's Avatar
jk240sx
There was a TSB from Dodge regarding the stripped caliper bolts. The Dodge parts guy even printed it off for me. Dodge states that using a thread repair kit is ok. I did mine in about 10 Minutes. I ordered a new caliper pin and got the Heilicoil kit for the thread repair. You want M9X1.25 kit, Heilicoil part# 5546-9. It only cost around $20.00 total for the pin and the Heilicoil kit. Better than buying a new knuckle!
I replaced my shocks in January. I went with Rancho RS2000. I couldn't be happier.
Old Apr 13, 2007 | 09:24 PM
emtsquad51's Avatar
emtsquad51
excuse my ignorance.. but what is a helicoil kit? Is that just a tap & dye set? Thanks for the info and I plan on calling my dealership on Monday to see if they have any info regarding this issue.
Old Apr 13, 2007 | 10:55 PM
jk240sx's Avatar
jk240sx
Heilicoil is a thread repair kit. Drill a new hole. Thread in the Heilicoil. Simple to do. All you need is a drill and needlenose pliars.
Old Apr 13, 2007 | 11:29 PM
imnothot02's Avatar
imnothot02
no, it works, but tap and dye is always the better plan...somtimes you cant however then use the Heilicoil brand system
Old Apr 14, 2007 | 12:37 AM
emtsquad51's Avatar
emtsquad51
so are you saying you drill out the pre-existing hole and insert this heilicoil thing? I'm pretty mechanically saavy, but this if the first time I've heard of this.. does it work something like a wall anchor? i.e. drill hole in wall, insert anchor, run screw in and the ancher spreads to hold it in place?
Old Apr 14, 2007 | 08:50 AM
jk240sx's Avatar
jk240sx
http://www.emhart.com/products/helicoil.asp
I can't find the copy of the TSB the dealer gave me but I am sure your dealer could print a copy for you. It gives detailed instructions for the thread repair. I got my Helicoil kit from local parts store.
http://www-odi.nhtsa.dot.gov/cars/pr...p;type=VEHICLE
Old Apr 14, 2007 | 02:55 PM
imnothot02's Avatar
imnothot02
yea not hard to do
