Talk about throttle bodys
Old Apr 12, 2007 | 07:40 PM
chris1974's Avatar
chris1974
Default Talk about throttle bodys
What can be expected ofinstalling alarger throttle body? Will you get worse gas miliage?
Any info for the newb would be greatly appreciated.
Old Apr 12, 2007 | 08:24 PM
f0x672's Avatar
f0x672
Default RE: Talk about throttle bodys
better airflow, better throttle response, if anything it will make the engine work less harder drawing in air through tight ducting... if anything it will help increase fuel economy, but you got to ask someone with a larger throttle body, im just assuming
Old Apr 12, 2007 | 09:12 PM
Chris's Avatar
Chris
Higher horsepower in the high RPM range, however you will loose a tiny bit ofhp/torque in the bottom RPM range.
