TIRES! LARGE! MUD! size?
Old Apr 10, 2007 | 04:48 PM
hawaiicjo's Avatar
hawaiicjo
Default TIRES! LARGE! MUD! size?
Alright fellas...I need some advice. I have a Stock to the bone 1999 Dodge dakota Sport Standard Cab 2wd Manual w/15" rims. I know it might sound crazy but i would like to put the largest size mud terrain on it that i can *WITHOUT LIFTING*. People have told me that the largest i can go is a 31x10.5x15 while others are telling me i will have a real problem with rubbing. Is there anyone out there that has already been through this that has some experience that i could draw from? PLEASE HELP!
Old Apr 10, 2007 | 04:58 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: TIRES! LARGE! MUD! size?
our trucks come stock with 31x10.5. thats the biggest I would go if your not gonna lift it.
you could do a 2" torsion/shackle lift for $50 then you could fit 32" or 33" depends on how wide ya go and what rims you will use.
Old Apr 10, 2007 | 05:18 PM
hawaiicjo's Avatar
hawaiicjo
When you say "our trucks" are you meaning 4x4? Do you think i would have to do any trimming with 31x10.5's? Alos i have never heard of a torsion/shackle lift. what is this exactly?
Old Apr 10, 2007 | 06:49 PM
f0x672's Avatar
f0x672
he doesnt have torsion bars.. hes 2wd... umm you can either do a body lift or a suspension.. otherwise your not gonna get much biggers tires... plus bigger tires puts a larger strain on your rear axle... if you search the forum you can find some info about that.. i know on the 4x4's.. the front axle will spilt from major abuse with large tires
Old Apr 10, 2007 | 09:17 PM
4x4kota's Avatar
4x4kota
I put the 31x10.x15's on my truck that originally came with 235/75r15's. I have no rubbing what-so-ever of any kind, but my truck is a 2001 4x4 SLT with stock suspension. Before i purchased my tires, i did a search on this site, and correct me if i'm wrong, but i remember reading something about some people having to do some trimming with those tires on a 2 wheel drive. Can someone chime in?
Old Apr 10, 2007 | 09:47 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
go to an auto parts store like autozone, get a 2" block lift kit, and then since your 2wd, I THINK you can get coil spring spacers (i may be wrong i drive an 06) that are also 2" of lift. The rear blocks are easy as pie to do, if you can do an oil change, or change a tire, you can tackle a block lift, or you could get it all installed, spacers for the front are usually like $75-$90, and the rear blocks can be had at autozone for $25 complete with longer U-bolts. They you can go any bolt up 32" or 33" tires, and not waste your money on such a small gain.
This is an easy and inexpensive lift, when your probablly going to spend $400 on these tires, whats another $100 to really get the look? I did my 06 with spacers and blocks, cheap budget solution, but its been done for years.
Old Apr 11, 2007 | 12:37 AM
emtsquad51's Avatar
emtsquad51
ORIGINAL: jonnymagnum
Is it true that if you do the torsion bar/shackle block lift that it will cause uneven wear on the tires and also handling issues?
Old Apr 11, 2007 | 12:49 AM
hawaiicjo's Avatar
hawaiicjo
some of these guys that know alittle more might be of more help but from my learning of this torsion/shackle lift it is possible to get bad alignment. which in turn could wear your tires uneavenly and cause handling issues. but a simple 50$ alignment could fix this. but like i said i have just recently been reading up on it so if i am wrong forgive me. but i believe that this is what you were looking for
Old Apr 11, 2007 | 02:32 AM
jonnymagnum
ORIGINAL: emtsquad51
aslong as you do an alignment afterwards you will be fine. I was getting ready to do it to mine... then I found out my engine is about to give up[:@]
Old Apr 11, 2007 | 09:00 PM
dodgedakota98luver's Avatar
dodgedakota98luver
what is the problem with your engine?
