Good oil change
Old Apr 13, 2007 | 09:34 PM
2000Dakotadriver's Avatar
2000Dakotadriver
Default Good oil change
So I finally got around to changing my oil, and in the past all my oil changes have been very very messy usally I will end up with a good portion of the oil on my person or on the floor. I don't know why it just ends up that way. However today was different I didn't get any oil on the floor and the only oil that got on me was from when I took the filter off. I also used mobile 1 synthetic for the first time. The oil that I drained most definitetly needed changing it was very broken down. I was just happy with the results of the oil change that I had to tell others.
Old Apr 13, 2007 | 09:43 PM
TheePlaymaker's Avatar
TheePlaymaker
Default RE: Good oil change
awesome...yea it took me a little while on my cherokee to get it were i didn't get it all over the place...a larger drain pan that holds more than the oil your trying to get out helps too[8D].
Old Apr 13, 2007 | 09:45 PM
imnothot02's Avatar
imnothot02
yea idk what the hell they were thinking not re-locating the filter on these things its not very user friendly
Old Apr 13, 2007 | 10:47 PM
peckens's Avatar
peckens
same problem on the 1st gens when removing the filter, a friend of mine changes oil at jiffly lube and he says Dakotas are always the messiest
Old Apr 13, 2007 | 11:36 PM
imnothot02's Avatar
imnothot02
i use fram, due to the sure grip...and welding gloves, does the trick, idk if fram is the best but my dad has always used them and had no problems...also i use castrol blended oil...duno what everybody else thinks but ive had great luck with their products
Old Apr 14, 2007 | 12:16 AM
2000Dakotadriver
Also somthing that I thought was a problem is either the location or the size or even both of hole in the skid plate where the drain plug is. When you pull the plug out the oil shoots out far enough that it just get up on top that skid plate and fills it up. So I now use a funnel. However I once used a funnel that had an exit hole too small so it just filled the funnel up. That made a huge mess.
Old Apr 14, 2007 | 01:30 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
yea the oil filter is in a really bad place on the 4.7s and the access hole they give you is barely big enough for the filter, i have never had any problems getting the drain plug out ofthe bottom tho, never made a mess out of that personally, and on the 3.9s the filter is located pretty well to avoid mess so i dont have too much trouble, its just the location on front of the engine that they decided to use for the 4.7s
Old Apr 14, 2007 | 02:41 AM
jonnymagnum's Avatar
jonnymagnum
huh, I always thought oil changes were pretty easy on these trucks. I've done harder ones.... you should try one on a gen3 dak. you will get oil every where but the bucket.
but I always use castrol GTX syntec 10w30 and a fram synthetic oil filter in both my trucks, well the 88 gets the used oil outta the 99 and a cheap filter.
Old Apr 14, 2007 | 06:08 AM
imnothot02's Avatar
imnothot02
my am's filter is on top of the motor, talk about dry starts...an it gets all over hell when ya change the oil
Old Apr 14, 2007 | 12:11 PM
shrpshtr325
THE ULTI-MOD
ORIGINAL: jonnymagnum
isnt that bad for the 88 to put used oil into it, i would never reuse oil
