Radiator Draincock
Old Apr 15, 2007 | 10:09 PM
DakinUK's Avatar
DakinUK
Default Radiator Draincock
Hi,
Does anybody know if the 2000 4.7 has a Radiator Draincock? Acording to the manual I downloaded off this site, it should be near the bottom on the left-hand side when facing the rear. I notice that the manual is actually for 2002 models so it might explain why I can't find mine!
I'm putting in a 180 stat and changing the coolant so want to get it all out. The stat looks like its the lowest point on the engine so it should all come out but the outlet for the rad is only about halfway down the rad so there's be quite a lot left in. The current coolent looks pretty good but it the Green type, so I want to replace it with the correct Red type, mixed 50:50 with distiled water, as I don't know when and what the prievious owner put in. Any advice would be most welcome.
Thanks,
Paul
Old Apr 16, 2007 | 01:41 PM
chris1974's Avatar
chris1974
Default RE: Radiator Draincock
Paul,
If you cant find the draincock for whatever reason, cant you just pull the bottom hose off of the radiator to drain the sys.?
Old Apr 17, 2007 | 07:25 AM
DakinUK's Avatar
DakinUK
As I tried to describe, the bottom hose isn't at the bottom of the rad! Its only about half way down,so would leave quite a lot of old coolant remaning.
Paul
Old Apr 19, 2007 | 07:14 AM
DakinUK's Avatar
DakinUK
Has any one changed thier coolant? If so, how did you get all of the coolant out of the Rad?
Old Apr 19, 2007 | 10:56 AM
Razorhorn's Avatar
Razorhorn
I haven't looked specifically at my Dakota 4.7L to see how difficult it is, but my first reaction if I were in your shoes would be to pull the radiator.
Old Apr 19, 2007 | 03:05 PM
DakinUK's Avatar
DakinUK
Looks like a small job is going to get whole lot bigger!
Old Apr 19, 2007 | 03:12 PM
jonnymagnum's Avatar
jonnymagnum
mine is on the bottom of the rad, but I have a 318 so its different.
and why do you wanna put the red stuff in it. I would stay with green, cause you still wont beable to get all the stuff out of the engine either........ unless you do a whole system flush.
Old Apr 19, 2007 | 06:23 PM
Erich_121's Avatar
Erich_121
i had one on mine. When looking at the radiator from the front of the truck it was on the lower righthand corner
Old Apr 19, 2007 | 10:56 PM
imnothot02's Avatar
imnothot02
may just have engine drains,...
Old Apr 21, 2007 | 07:32 AM
DakinUK's Avatar
DakinUK
I thought that after much debate on this forum that Red was the way to go as far as coolant goes? All I know for definite is that whatever one you choose, you shouldn't mix the two. I've already bought some long-life (Red) coolant with the required specs (can't remember them now but it was in a few posts on the sublect) and I've mixed it up in a 50:50 solution with analitical grade de-ionised water (did I mention I work at a univercity!). Its now a pinky shade of orange.
I can't belive they put the outlet pipe on the rad only half way downthe rad as it give less opertunity for heat exchange. The only reason I can think of is that the trany oil cooler is in that bottom section of the rad (the ol pipes go in just below the rad outlet pipe).
I'm off to look for that draincock, as acording to Erich's post, I've been looking on the wrong side of the car!
Thanks all,
Paul
