pulled p0748 code
Old Apr 20, 2007 | 01:37 AM
chrissg1's Avatar
chrissg1
Default pulled p0748 code
ok i pulled p0748 code from my 97 dodge dakota has v6 so i replaced all solenoids and pressure sensor still geting the same code can shift but only manually overdrive wont engadge i think o/d is computer controled also acts like it has bad gas but not all the timealso ihere a relay clicking on or off now and then but i thought the trans relay is under the hoodwitch i checked that also by switching it out with one of the others on the same fuse panel
its driving me crazy so i called dodge dealer to put on there computerand they say with as many miles i have i need a new transmission with as much smarts i have i think its not mechanical its computer controledi think itsnot geting a signal from pcm to trans also does dealer computer pull and dig deeper than my actron hand held scaner canany one help me thanks
[IMG]local://upfiles/61144/096899C9BE144FFC934C2B0B0D6E217D.jpg[/IMG]
Old Apr 20, 2007 | 01:45 AM
imnothot02's Avatar
imnothot02
Default RE: pulled p0748 code
how many miles what tranny what truck...
that is one massive catfish
Old Apr 20, 2007 | 01:52 AM
chrissg1's Avatar
chrissg1
its a 97 dodge dakota v6 has 155825 miles
Old Apr 20, 2007 | 01:55 AM
imnothot02's Avatar
imnothot02
ouch eya its proaly due for a rebuild thats alot what kinda maint ya done on it you the orignal owner?
have the fish pull ya around!
Old Apr 20, 2007 | 03:05 AM
User's Avatar
User
if you want deeper readings, take it to a NTB or somone that has a OBD2 handheld/laptop reader. It gives you all the specs of your truck, it also gives you detailed descriptions on why your PCM is throwing that code and how to fix it, and what may cause it to do that.
I know my work (NTB) has one, we scan peoples **** all the time.
