Hey i Need help, Its raining and its not starting
Old Apr 26, 2007 | 03:05 PM
thekorn99999999's Avatar
thekorn99999999
Default Hey i Need help, Its raining and its not starting
well basiclly every time it rains my dodge wont start i have checked all the wires all good but im guessing that the disributor has a crack but i dont know if theres any other solution... please help...
Old Apr 26, 2007 | 04:40 PM
thekorn99999999
Default RE: Hey i Need help, Its raining and its not starting
new update no water in the cap and there is spark from the coil motor turns but wont start any ideas what next to check?????
Old Apr 26, 2007 | 05:17 PM
English_Dakota's Avatar
English_Dakota
could be anything, is there fuel? uu run outta gas? blown a fuse? the list is endless.......
Old Apr 26, 2007 | 09:31 PM
f0x672's Avatar
f0x672
id replace the cap, rotor, wires and plugs just to be on the safe side, my cirrus used to stall in rainy weather, replaced the plugs and wires, problem solved
Old Apr 26, 2007 | 10:37 PM
turkeyhunter1962's Avatar
turkeyhunter1962
Do yourself a huge favor and buy a tube of dielectric compound. Use it on each terminal on the distributor and at the coil and spark plugs. Also evey electrical connection that you can separate do so, carefully clean any corrosion you find, put some of the dielectric compound in the connection and connect it back together. I did it and no more problems.
