Removing Cat
Old Apr 27, 2007 | 10:15 PM
varsis's Avatar
varsis
Default Removing Cat
I thought i would post this, I am removing my cat converter. i will post some pictures of the cat after I remove it. Because it is not ratteling but I think it is plugged.
Old Apr 28, 2007 | 09:56 AM
racin_40's Avatar
racin_40
Default RE: Removing Cat
hopefully you will reinstalla new oneunless you dont care about milage ,if i am not mistaken we have a O2 sensor for and aft the cat and removing the cat all together will send an open loop to the pc and make it run rich which in turn will use more fuel .
and also it wil not pass emissions testing without it
Old Apr 28, 2007 | 10:00 AM
BAnders's Avatar
BAnders
racin, running lean uses more fuel, running rich means too much fuel
Old Apr 28, 2007 | 10:09 AM
racin_40's Avatar
racin_40
ORIGINAL: BAnders
how could that be possible ? running it lean will starve it for fuel therefore ,1 not run right and 2 no power
when it runs rich it will dump more fuel in like in warm up mode till the computer is told to lean it out when up too temp
thats the reason behind most ppl running a cooler thermostat so the motor is running cooler so therefore more fuel is added thinking it is still in startup mode to deliver more power
Right?
Old Apr 28, 2007 | 12:31 PM
varsis's Avatar
varsis
post cat o2 sensor does not affect the air/fuel mixture. Only pre cat does this. If anything I will get better millage as I get about 50 KM"S to a quarter of a tank which is redicolous (I calculated 8.4 mpg.)
Old Apr 28, 2007 | 02:37 PM
varsis's Avatar
varsis
My rear o2 sensor must be busted as I removed the cat and no check engine light. But as for the removing it a pain because it was welded in, but my cat converter is off and it sounds like I have an exhaust! Pretty good for just 8 bucks worth of pipe. lol
Old Apr 28, 2007 | 07:16 PM
boohoops's Avatar
boohoops
bad o2 sensors dont always giv u a c.e. and it duz sound like ur cat is bad with that mileage.i just replaced mineand wat an improvement! truck sounds better to
Old Apr 28, 2007 | 10:03 PM
varsis's Avatar
varsis
heh mine sounds awesome, also fixed my idle problem. It would like almost die at times but is fine now.
Old Apr 28, 2007 | 11:50 PM
BAnders's Avatar
BAnders
if the computer is thinking the mixture is too lean then it will start dumping fuel and if it is too rich it will restrict the fuel amount
Old Apr 29, 2007 | 12:15 AM
imnothot02's Avatar
imnothot02
i realy think ur gna want a simulator...but see what ya get for mpg...
