HELP!!!4 wheel drive stuck in hi!!!! HELP!!!
I hope someone has seen this before, the dealership didn't know what it was when I took my truck in. Last weekend my battery died so I put the truck in neutral and rolled it down the hill (which I learnd was risky) It rolled about 100 feet to a stop where I pulled the battery and put in a new one.
I had been in 4 hi pulling a trailer, now that I have the new battery I don't have any lights on my 4 wheel controldial nor will it shift out of 4 hi, I can turn the dial but don't get anything, I have disconnected the battery, rolled the truck in the opposite direction several time. The truck drives fine, its just stuck in 4 hi
Any HELP PLEASE
Any HELP PLEASE
what year is it?.. msot likely the pcm needs to be reflashed.. some of the daks ( at least mine) were reflahsed for transfer case problems, it would shift out of gear and cause chaos
Unfortunately it sounds like you might have fried the transfer case solenoid. I'd pull the front driveshaft out before driving it around too much though, you're apt to break the t-case if you don't.
hes gonna break more then the t-case... doesnt 4hi lock up the rear axles?.. or is that the front? cause it was just a plain differential it would just act like AWD but something gets locked up
No, putting it in 4wd only engages the transfer case. There is no center differential - differential implies that there is a difference in output speeds allowed. The non-AWD transfer cases have a locked 50/50 front rear bias, and that's what will break. The front differential is open unless someone installs an aftermarket limited slip or locker, and the rear axle is either open or limited slip from the factory, or locked if added later.
He could start popping U-joints or CV joints, which would be better than breaking the actual transfer case, but those are way cheaper to fix and Murphy's law states that the most expensive link should break first.
Thanks for all the tips... just my luck it wouldn't be an easy fix.
I will check into the pcm, as for the transfer case, if that went out would that also cause the lights on the dash to go out?
To answer a few questions: Its an '02
Yeah, when my transfer case control module went out the switch quit lighting up and wouldn't do anything.
