Fu*king HO upgade....Fu*ckin Throttle body size??
****Updated*** (i am taking travis's advice on the title) hehehe
In the next couple of days i will be doing the HO upgade. Complete with intake, throttle body, and cams. I am going to go with the 206* cams, and just the stock HO intake. I have read alot about throttle bodys and have come to a conclusion that the "true" 68mm is best for the STOCK engine, but am wanting some opinions on what you fellas think would be best for the HO set up.....
Oh....keep in mind that i will be adding dual forced induction soon as well! Yeeeehawww!! [sm=gears.gif]
RE: HO upgade....Throttle body size??
i went with the 70 mm from the fastman. it was plenty because i too have the 206 cams. instead of getting the 206 get the new 212 that just came put from krc performance cheaper in price and suppose to better. also if you dont get the pcm flash the throttle body wont be as affective nor will the cams
