Trans fluid
Old May 12, 2007 | 09:18 PM
klings designs's Avatar
klings designs
Default Trans fluid
If i were to change my trans fluid, and filter and wanted to use full synthetic. Would that be bad to mix whatever is left in their and to put full synthetic with it?
Old May 13, 2007 | 06:12 AM
varsis's Avatar
varsis
Default RE: Trans fluid
I would probably guess yes just because it is synthetic. Also consider the millage, and try and mix some together yourself (Not in the transmission and see how they blend if they do at all.)
Old May 13, 2007 | 06:58 AM
klings designs
what do they put in there for stock?
Old May 13, 2007 | 02:30 PM
varsis's Avatar
varsis
ATF + 3 or 4
Old May 13, 2007 | 03:01 PM
imnothot02's Avatar
imnothot02
that would be the worst thing that you can do to your transmission, well other than n bombs tow in o.d ect.
Old May 13, 2007 | 05:27 PM
User's Avatar
User
do a full fush.. got to get that fluid out of the TC also. Do a full flush with some Mopar ATF+4 (buy it at walmart) and go to your local dealership and get a mopar filter and gasket for the tranny case, the ones napa, oreillys, and places like that sale dont work as good, they go bad faster.. and sometimes break off, the mopar one is made of a rubber type, the other ones are cheap..
need about 16qts to flush, and 1 filter and gasket.. 13$ for gasket and filter, then another 64$ for the fluid, and if your doing at a shop another 100$ in labor.. even though its easy as **** to do.
Old May 13, 2007 | 07:16 PM
jonnymagnum's Avatar
jonnymagnum
ya, for a tranny flush you will have to go to a shop and get them to do it. I got mine done last year and it was around $100. and I changed to synthetic too.
Old May 13, 2007 | 09:31 PM
klings designs
why would it be bad to mix them wouldnt it be a blend?
Old May 13, 2007 | 09:40 PM
padodgeram's Avatar
padodgeram
ORIGINAL: klings designs
Its not bad to mix syn with regualr trans fluid.. but to get the full effect of the syn do a flush...
Old May 13, 2007 | 09:41 PM
klings designs
ORIGINAL: imnothot02
So this isnt true?
