did something stupid
Old May 15, 2007 | 01:13 AM
codered's Avatar
codered
Default did something stupid
I took my 99 dodge dakota through some pretty deep mud puddles...about 1 foot or so, at a pretty fast speed (15mph) then later on, the truck stalled out...now its really hard to start it, and it idles at a lower rpm and sounds bad. worse yet, when i put it into gear it stalls out completly after 5 seconds...my friends say i just got the engine really wet, and it should be fine after i let it dry out...are they right or did i screw it up worse?
Old May 15, 2007 | 02:25 AM
2000Dakotadriver's Avatar
2000Dakotadriver
Default RE: did something stupid
Sounds to me like you got water under your distrubutor cap. Pull it off dry it and put it back together, no big deal. Just out of curosity shen your friends say "got the engine really wet" what does that entail to them?
Old May 15, 2007 | 02:40 AM
jonnymagnum's Avatar
jonnymagnum
ya, sounds like the distributor got wet.
Old May 15, 2007 | 12:42 PM
Erich_121's Avatar
Erich_121
either that your your air filter is soaking wet.
Old May 15, 2007 | 01:28 PM
01dodgedriver's Avatar
01dodgedriver
the engine spins over right?
Old May 15, 2007 | 03:46 PM
codered's Avatar
codered
yeah it starts...but it chugs alot as it starts. then the idle is really bad...doesnt get better even after a few minutes. right now im just lettin it sit and dry out
Old May 15, 2007 | 04:29 PM
Erich_121's Avatar
Erich_121
did you check the air filter?
