Replacing U joints
Old May 17, 2007 | 10:58 PM
F1ashman's Avatar
F1ashman
Default Replacing U joints
Getting ready to replace my u-joints. Have three to replace. Can they be done without pulling the driveshaft completely off the truck?. Anyone replaced them while the drive shaft is still on the vehicle? I do have the U-joint toolkit from Advance. Will be doing them on jackstands in the garage. Any recommendations or tips? Thanx in advance.[sm=feedback.gif]
Old May 18, 2007 | 02:59 AM
jonnymagnum's Avatar
jonnymagnum
Default RE: Replacing U joints
umm ya, I would definatly take the dive shaft out. if you have an aluminum drive shaft then they will be a pita to take out.
I did mine in about 1/2 hour but I have a press though.
Old May 20, 2007 | 04:32 AM
F1ashman's Avatar
F1ashman
How about replacing the center support bearing does that have to be pressed on and off at a machine shop? Thanx in advance.
Old May 20, 2007 | 05:56 PM
Ablaze's Avatar
Ablaze
you can do all the "pressing" in a normal table vise.
Old May 20, 2007 | 06:09 PM
imnothot02's Avatar
imnothot02
realy simple job, just start into it it will all make since...
