Changing Thermostat from stock 195 to lower?
Old May 20, 2007 | 11:42 PM
Big_Green's Avatar
Big_Green
Default Changing Thermostat from stock 195 to lower?
Was looking on the JET website and they got a Thermostat that is 180 instead of 195 for my truck, Iv seen some ppl have them on there truck on these website. Is it worth doing? Any more power gains? Guessing the truck would run cooler, or is it something you would do to a truck with mods to keep it from running hot? Is it hard to change and do?
Thanks for help
Old May 21, 2007 | 12:30 AM
Mean Green's Avatar
Mean Green
Default RE: Changing Thermostat from stock 195 to lower?
You gotta start doing searches man. The 180 keeps the engine running cooler which makes more power (very small increase but an increase nonetheless). The drawbacks to this are that your heater will suck more than it does now and it will be harder to pass emissions since the higher temp burns cleaner. The gain is better with other mods like a CAI, TB, headers, exhaust, and a tuner.
Old May 21, 2007 | 12:31 AM
superdak05's Avatar
superdak05
you wont see any power gains out of them. but most of us who have cam kits and programmers put them in. for 10.00 you can get your 180 stat from napa part number is 530080. easy to install. just follow your top radiator hse to the thermosta housing and remove. check first to see if the alterator or a/c condensor is in the way. you may need to remove them to get at the housing.
Old May 21, 2007 | 01:15 AM
Big_Green's Avatar
Big_Green
ok thanks for help i didnt think it would be that great of a increase, guess that is a passs and ill be saving for headers and a TB, wat size stock TB does the 5.2 come with? wat be worth upgrading too?
Old May 21, 2007 | 01:24 AM
Mean Green's Avatar
Mean Green
Go to www.thefastman.com and talk to Dan he will let you know the best size TB to slap in there.
Old May 21, 2007 | 01:53 AM
jonnymagnum's Avatar
jonnymagnum
I have a 180 stat on mine for my tuner. I just went to crappy tire and bought a fail safe one.
Old May 21, 2007 | 02:19 AM
Big_Green's Avatar
Big_Green
wat kind of tunner you got? superchip? so im guessing you dont need one unless your running a program the? btw has your cai from ebay yet?
Old May 21, 2007 | 02:23 AM
jonnymagnum
ya, I got superchips. its set on performance, but tomorrow I'm putting in on stage one. gas is getting to expensive now and I cant afford to be putting premium in it since I've been putting alot of kms on it.
and my CAI still hasnt came in. I guess cause of the holiday hopefully next week
I still gotta get my roll pan on too.... I've been way too busy these past couple weeks[:@]
Old May 21, 2007 | 02:32 AM
Big_Green's Avatar
Big_Green
would recommed getting one? If on stage 1 do you get good gas mileage/performance gain? What model did you get and where? Does the performance mode give you good power over the stock?
Old May 21, 2007 | 02:37 AM
jonnymagnum
I got mine off a guy off this forum. I noticed a difference, and better MPG if I'm not givin er.
I noticed it shifted better and had better throttle response, the best thing about it is that you can view/clear codes.
