pulling out radio
ORIGINAL: reeserx
how do i take out the stock tape player in my 98 dakota sport? i see no screws or anything in there, i wanna put a new one in there thanks
Get a toggle bolt, insert it into the tape deck (be sure the toggles open), attach a chain and run it out the pass. side door, and wrap it around a tree. Get in the truck, floor it and drop the clutch.
She'll come right out!
[quote]ORIGINAL: chris1974
Or.......
[/quote
lol that would work, but the first idea is what you need to do i think the bolts are 10mm but im not 100% sure on that and then it just slides out and the wires unclip from the back and then you get to have fun soldering wires for your aftermarket stereo ENJOY
ORIGINAL: reeserx
[/quote
[/quote]
Or.......
[/quote]
I like that idea, exept i'd use the rear sliding window to feed the chain through.That way the deck will pull out straight and not on an angle!
Or.......
[/quote]
just take off the dash piece (that goes around the cluster and a/c vents) it just clips holding them in...it will sound like it is breaking but just keep pulling it..lol...also if you have an atoumatic...it is easyier to shift it into 1st!! the unscrew the 2 10mm bolts and you in!!! i hope this helps!!
