lift kits
Old May 24, 2007 | 01:10 PM
MTHillBilly's Avatar
MTHillBilly
Default lift kits
im looking at lift kits both syles any one have any info pros con or site to check out post a note can use all the info
Old May 24, 2007 | 10:21 PM
imnothot02's Avatar
imnothot02
Default RE: lift kits
pro its taller con its taller, little more info on what ya want since there are about 100 different lifts avalable...how high ect...
Old May 25, 2007 | 02:23 AM
MTHillBilly
well i was thinking around 2 to 3 inch body for now then 3 to 4 inch specion lift later
Old May 25, 2007 | 02:27 PM
MTHillBilly
ok just so you know this is my first dak i heard i could tighten the tousion bars and get some height? an if i did how high and then what would i have to do to raise the back
Old May 25, 2007 | 04:17 PM
norcalmudbogger's Avatar
norcalmudbogger
depends wat year DD u have bro, 97-99 Tuff Country makes a 5.5 inch suspension lift, runs a lil over a thousand, for Durangoyears 00-03 Rancho makes a 3 inch suspension lift. the body lifts are far cheaper and easy to install, i think spending thousands of dollars to put on a 3 inch suspesnion lift is kinda dumb, if u can get the 5.5 id recomend it, body lifts are chill tho, make sure to get the gap guards in the front tho! u also have to do sum extensions on ur 4x4 extension **** w/ the body lift
Old May 26, 2007 | 11:57 AM
racin_40's Avatar
racin_40
bogger is correct but the pricing is alittle off
JC whitney has the Tuff country 5.5" for $1399 which includes everything which is nice but looks rather complicated to install for the average joe
body lift i have never been a big fan of simply because they stress the steering linkage and in some case you have to modify the floor for the shifter and the gaps between the front and rear bumpers
but thats my opionion and everyone has 1
Old May 27, 2007 | 02:48 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
What I would do, if you have a 4x4, is before spending alot of money, crank the torsion bars, get 2" up front, then throw 2" blocks to the rear, on stock shocks. A 2" lift is more then you would think. You just may be happy and you would probablly only wind up spending about $30-$50 for the bocks, the bar crank is free.
Old Jun 1, 2007 | 04:42 PM
MTHillBilly
thanks yea ive already twisted it up still would like around 3 more any ways decided on a body lift for now
Old Jun 17, 2007 | 09:13 PM
falcon241073's Avatar
falcon241073
What brand, how much, and where to get the shackles for the rear 2-3 innch lift? Would blocks be better?
