Need a little help
Ok guys, i am in need of a little help here. My truck (2000 Dodge dakota 3.9) was parked all winter because I was gone. When i got home and went to drive it this spring the abs light and parking brake light were on and stay on. I did a search on this website and people say that it is the speed sensor. I checked and the speedo works all the way from start up to cruising speeds. So that rule the sensor out. Right? The other thing was people said it could be cleared by starting the truck, putting the parking brake in and releasing it. I tried this and the lights would clear for about a second after it was restarted and then come right back on. Do you guys have any other suggestions I can try or know what it could be. Thanks for any help.
Blake
Blake
i would try disconnecting the battery for a few minutes....i'm a motorcycle mechanic and when we reset code...we touch pos. and neg. together and hold it for a few seconds....but wait for someone else to post something!!!
well you can pull the code(((put the key in and turn it to the ON position..(not engine running)...do that 3-4 times...on the last time...leave it on the ON position)))...a code should appear...P....
i believe that it how it works!! try it and let me know!!
there is no code for it. I tried that and it comes up as (p done). If it is the speed sensor then my speedo wouldn't read until higher speeds, if I understand right. Everything seems to work fine. So I might just leave it for a bit while I check out other solutions. Gonna get amanual from the library today.
Trending Topics
umm thats not true i have a friend whose speed sensor went bad setting off the lights, and his speedo still worked fine, its wierd if you ask me but thats how it happened
