Hello i need your advices guys !
Old May 29, 2007 | 11:16 PM
raptor700RR's Avatar
raptor700RR
Default Hello i need your advices guys !
I just did an oil change today. what happened, is after having drained the oil and changed the filter, i noticed that i bought the wrong grade of oil. instead of having a 4.4 litres of Castrol High mileage 10W30, i hada container ofCastrol high mileage 5W30. Usually, i use 5W30 for winter and 10W30 for summer. Is the 5W30 is still good, or its too thin for the summer weather. And if it is, is lucas oil stabiliser would help bringing my oil thicker ? Thank for your input ! oh and is that high mileage thin is only bull**** or it does improve something ?
Old May 29, 2007 | 11:25 PM
Mean Green's Avatar
Mean Green
Default RE: Hello i need your advices guys !
It's not a big deal but just so you know you want to stick to the sameweight all the time. Unless you are getting well below 0* in the winter I would just use 10w30 all year long. As for the higher mileage thing I'm sure it is just to sell you a few quarts of oil. If you want to be really nice to your engine use synthetic.
Old May 30, 2007 | 12:20 AM
jonnymagnum's Avatar
jonnymagnum
ya, I would switch over to castrol GTX syntec 10w30.
5w30 will be fine for now, but 10w30 is alot better.
Old May 30, 2007 | 10:21 AM
imnothot02's Avatar
imnothot02
it wont hurt a thing little lighter oil, but wont destroy the motor no...
Old May 30, 2007 | 07:27 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
no not a problem my dads manual actually says that if you cannot get 10w30 that the next best one to use is 5w30 so go ahead and use it as it wont hurt the engine and it is what he has been running until just recently because we just started seeing the 10w again and he put like 60000 on it w/ 5w oil
Old May 30, 2007 | 09:24 PM
raptor700RR
oki thank guys, it good to have words from the others dakota owners !
Old May 31, 2007 | 01:43 AM
4x4kota's Avatar
4x4kota
i usually throw in about 1/2-3/4 of a bottle of lucas anyways. It all depends on what i feel haha. But as the difference in high mileage oil goes, all that they do is add a few more additives that are a benefit to worn engines. I'd just stick with lucas.
Old May 31, 2007 | 09:07 AM
deranged's Avatar
deranged
Unless you're driving in extremely high temperatures, say 90 degrees plus for extended periods at high speeds,you should be fine. As stated the best thing is to run synthetic.
Old May 31, 2007 | 11:45 PM
ptrapper65's Avatar
ptrapper65
ORIGINAL: deranged
I run with Mobil 1 5x30W. I change it every 10,000. It's worth the extra $ and time between oil changes.
Old Jun 5, 2007 | 01:53 PM
tntitans21399's Avatar
tntitans21399
I usually put the normal 10W30 and throw in a quart of synthetic. It won't hurt to add the 5W30, but I would just stick with 10W30 year round.
