Exhaust
Old Jun 6, 2007 | 02:34 PM
supramr2's Avatar
supramr2
Default Exhaust
Hey whats up , I have a 2003 dakota 3.9 v6 and at idle I can feel the exhaust come from the engine all the way back while sitting in the truck, is this normal.
Old Jun 6, 2007 | 07:27 PM
varsis's Avatar
varsis
Default RE: Exhaust
Don't think so. I think that the exhaust is leaking under you and I would think you should look for the leak, because you might get carbon monoxide.
Old Jun 6, 2007 | 07:54 PM
supramr2's Avatar
supramr2
Default RE: Exhaust
Im not getting any leaks in the exhaust , I just feel the vibration of the exhaust and it's stock exhaust with k&n filter
Old Jun 6, 2007 | 08:02 PM
chris1974's Avatar
chris1974
Default RE: Exhaust
Maybe im missing something (its been a very long day) but what do you mean you can "feel the exhaust"?
You say you dont have any leaks? Does the truck run ok?
Old Jun 6, 2007 | 08:25 PM
supramr2's Avatar
supramr2
Default RE: Exhaust
The truck runs fine,no problems,but I can sit in the truck and feel the exhaust go from the front to the back
Old Jun 7, 2007 | 12:20 AM
daddydwg's Avatar
daddydwg
Default RE: Exhaust
That's called an acid trip. As long as you're not driving while on acid, enjoy your exhaust sensation.
Old Jun 7, 2007 | 12:31 AM
batman13's Avatar
batman13
Default RE: Exhaust
look for a loose or broken bracket, when i got mine one of the front mounting brackets was broken, allowing the exaust to beat against the frame in the back
Old Jun 7, 2007 | 12:46 AM
ptrapper65's Avatar
ptrapper65
Default RE: Exhaust
ORIGINAL: supramr2
I felt this way on LSD once. But I was feeling the air from the vents.
I think you should elaborate on your problem
Old Jun 7, 2007 | 01:50 AM
4x4kota's Avatar
4x4kota
Default RE: Exhaust
Feel the exhaust? as in your sitting there and the truck is shaking a little bit? Maybe running a little rough? Maybe a broken rubber mount and the exhaust is rubbing against the frame? Give us more info here to work with...
Old Jun 7, 2007 | 02:42 AM
98R/TDak's Avatar
98R/TDak
Default RE: Exhaust
yea cause if u have the full exhaust system going out the back you shouldnt really feel it...on my 5.9 i have the exhaust dumped right after the muffler so i can feel it just cause it resonates? if i spelt that right....underneith the truck...before the only way i "felt" the exhaust was cause the engine was running a little rough and would vibrate the whole cab
