New dakota owner questions - need help!
Old Jun 18, 2007 | 03:51 PM
kotaman1's Avatar
kotaman1
Default New dakota owner questions - need help!
Hello,
Just purchased a 1998 Dakota (3.9L/V6) with 79k miles! It took some time to find one with low miles!! I have a few questions that I could use some assistance with: (1) Prior to buying this truck, I had researched the vehicle and found out that a lot of owners were replacing trannys. Why is this? I plan to tow a small boat (about 1600-1800 pounds). Will this be okay without having to buy a heavy duty tranny or installing trans cooler? (2) I noticed that the truck has a really good set-up for an after market K&N Filter intake kit. If you agree, what model do I need and how much will that set me back? Will it require a lot of mods to install? (3) It came with a sunroof! Is this nromal or was it an aftermarket add-on? The owner I bought it from didn't know. He said he got it that way from the prior owner before him. Are there any water leak problems associated with this sunroof that I should know about? Thanks for all you help. kotaman!
Old Jun 18, 2007 | 04:26 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default RE: New dakota owner questions - need help!
umm i would guess that the sunroof was aftermarket, and if u wait long enough, alot of the guys on here have bolt on cai and the tranny probs are mostly w/ v8s which are used for towing and equipped w/ the 42re tranny, the v6s dont really put out enough power to destroy them, at least not that ive heard
Old Jun 18, 2007 | 05:54 PM
Red4.7's Avatar
Red4.7
Whats up man . i got a cold air intake from ebay for really cheap and it took maybe five minutes to install
Old Jun 18, 2007 | 06:27 PM
rtkota5point9's Avatar
rtkota5point9
Be weary of Ebay kits. Most of them are "HOT" air intakes.
Old Jun 18, 2007 | 06:42 PM
shrpshtr325
THE ULTI-MOD
that is true, make sure that the e-bay kit is a real COLD air intake if you go that route
Old Jun 18, 2007 | 07:01 PM
Billiam's Avatar
Billiam
Or relocate them to make them cold
Old Jun 18, 2007 | 07:13 PM
jonnymagnum's Avatar
jonnymagnum
and watch out on wich ones you buy too. some of them are total junk. make sure it atleast has a heat shield. I bought one and after a lil modification it fit.
