Drop a Hemi in? Worth it?
Hi, Well I have been looking on the internet for putting a hemi into my dakota with the ram tranny too. But the problem is that I am not sure how much work this is and how much this work would do. I just think that the dakota would be a nice change to have some power and I might even have my engine going no power in it. I had it set for cruise at about 75-80 miles to hour. But it would climb a hill and not get going agian unless it shifted down. I had it going about 70 miles an hour when It hit the almost flat slope at the top of the hill. So Either I fix this or do a swap. or try and pawn it off on someone stupid. lol
RE: Drop a Hemi in? Worth it?
I have read what The guy did, but he used the stock tranny behind the 5.7L hemi. He finally figured it out and he has it running fine now, a bit of rough idle. But I think everything would be swapped. All done by hand of course and I know that I could handle it becuase i removed the tranny on my own. I know I would have to redo the oil pan, simple fix for me. I know a friend who has a dad who does machining so If I really need I can get that done. But I do think this truck really lacks power right now, It needs to be either fixed or junked on someone else. But Is it maybe worth it for me. Will my diff and front diff handle this? I would probably swap in the hemi's transfer case. Make it simpler. Might just need a new drive shaft. Ofcourse I would be buying a hemi which was drivable just scrapped.
Keep in mind everything that would have to be done. You would need a new driveshaft, rear end, gauges, radiator, mounts, and on and on. This can and has been done, but just keep in mind that you could probably get a very nice used truck with plenty of power for the amount of money you are about to drop in this project.
