Helix coil
Old Jun 19, 2007 | 06:15 PM
dak3.9's Avatar
dak3.9
Default Helix coil
I need to install an 02 sensor on a cat that does not have a spot to screw an 02 sensor into it. So i was told to use a helix coil to drill a hole into the cat so that i can put the o2 sensor in. Has anyone ever used a "helix coil" and installed an o2 sensor before?
Old Jun 19, 2007 | 06:30 PM
yellowjacket99's Avatar
yellowjacket99
Default RE: Helix coil
It's "heli coil", and I've used them, but not for that. I don't know if the wall of thecat is thick enough for that to work. Usually what I've saw isa nut for the correct threads of the sensor is welded on top of a hole drilled in the exhaust.
Old Jun 19, 2007 | 06:55 PM
jonnymagnum's Avatar
jonnymagnum
ya.....umm...... O2 sensors dont go inside the cat. they are in the pipe before and after the cat.
Old Jun 19, 2007 | 09:09 PM
f0x672's Avatar
f0x672
tip: when you drill, put grease on the drill bit to catch all the debris so it doesnt go into your cat
Old Jun 20, 2007 | 02:06 AM
98R/TDak's Avatar
98R/TDak
yea it normally should go before and after...but if u must put it in the cat for whatever reason that is..ive done the whole weilding a nut into a drilled hole and then screwed something that matches the threads...works pretty good i suppose if u do it right
