45RFE Cooler Lines
Old Jun 24, 2007 | 10:28 PM
4.7DakotaQC's Avatar
4.7DakotaQC
Default 45RFE Cooler Lines
Which line on the trany itself or on the radiator is the trans cooler return line?
Old Jun 25, 2007 | 01:28 AM
4.7DakotaQC
Default RE: 45RFE Cooler Lines
Just in case of any confusion, the 45RFE is the 5 speed auto trans.
Old Jun 25, 2007 | 01:35 AM
f0x672's Avatar
f0x672
well im the picture of the 01 manual, it's the bottom cooler line as it shows
Old Jun 25, 2007 | 01:41 AM
4.7DakotaQC
on the trans or radiator?
Old Jun 25, 2007 | 02:01 AM
f0x672's Avatar
f0x672
transmission, sorry about that
Old Jun 25, 2007 | 02:06 AM
4.7DakotaQC
No problem. Thanks. You know that there is no info on the internet anywhere on this.
Old Jun 30, 2007 | 12:15 AM
grcforce327's Avatar
grcforce327
Just pop one of the lines on the radiator.While running,if fluid comes out of the radiator, it's the return.If fluid comes out of the line,it's not.Why do you ask?.I would suggest replacing the accumulator plate on the valvebody with one from Transgo.The factory plate gets pounded and breaks and strips the hold down bolts
