2nd gen POS
Old Jun 27, 2007 | 11:01 PM
stang4aDakota's Avatar
stang4aDakota
Default 2nd gen POS
Ive had my dakot for less than 2 months and already ive had to replace the governor pressure sensor and solenoid and now I have to replace the radiator.
Any other problems I should look for?
Old Jun 27, 2007 | 11:08 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: 2nd gen POS
how many miles is on your dak? was it beat to hell before you bought it?
Old Jun 27, 2007 | 11:09 PM
stang4aDakota
119k
mint condition someone put alot of love into it
Old Jun 27, 2007 | 11:32 PM
f0x672's Avatar
f0x672
transmissions are a weak thing in all dodges... ever since they shoved computers into the transmissions, all hell begun, especially the 90's... radiator is just a random problem you happen to run across.. otherwise... enjoy your stay
Old Jun 27, 2007 | 11:36 PM
batman13's Avatar
batman13
things go bad, I would agree that the transmission would be a weak spot,
and the occasional shopping cart,[:@]
Old Jun 27, 2007 | 11:42 PM
stang4aDakota
I understand the tranny thing was random theres even a TSB about it. Kind of annoying it didn't happen till after I bought it.
And the radiator it kinda gets to you when you come home from work and see all your radiator fluid on the ground.
and a new radiator isn't exactly cheap. LOL
Old Jun 27, 2007 | 11:44 PM
stang4aDakota
Any other things I should check to do some preventive maintence?
Old Jun 27, 2007 | 11:49 PM
f0x672's Avatar
f0x672
check your cap, rotor, plugs, wires, test the battery or bring it to advance auto or somewhere that will test the battery for free, brakes, rear differential fluid, if 4x4, transfer case fluid, just basically a full on inspection, anything out of the ordinary check it out.. and yea from what i see, our trucks are notorious for killing o2 sensors, they can be shot and wont throw a code, whats your gas milage?
Old Jun 27, 2007 | 11:51 PM
User's Avatar
User
Waterpump, Loose exhuast manifold bolts, Power steering pump, upper balljoints (recall), thats all i can think of right now.
Old Jun 27, 2007 | 11:55 PM
stang4aDakota
I did a full tune up when I bought it plus cleaned the carb new pads rotors and drums
Ball joints were new its a 97
gas mileage is decent Hwy is about 23 around town close to 18
The only thing I can think of is the heat today (it topped 100 in my area)
pressure blew my welds or it blew my water pump
