A/C Not Blowing Properly
RE: A/C Not Blowing Properly
I am trying to figure out the same issue with my 2000 Durango. Last week I pulled the HVAC box to change a leaking evap and verified the blend door and diaphragms for the ducts are working properly. I also installed a new core and blower motor since I was there. The next step is to check the resistance for the high setting at the blower resistor. At the highest setting the resistance should be zero. Hopefully in the next wekk or so I can check it. I will let you know.
