back glass weatherstriping
Old Jun 29, 2007 | 07:23 PM
batman13's Avatar
batman13
Default back glass weatherstriping
finally got my new window but it dosent have the weatherstripping, do any of you know where i can find it?
or if/how i could re-use the old one? (doubtful)
Old Jun 29, 2007 | 08:14 PM
RP Racing940's Avatar
RP Racing940
Default RE: back glass weatherstriping
Dakotas rear windows are encapsulated which means they are GLUED IN with a special urethane. You'll need to take the plastic out from around teh inside of teh window and look to see if theres any hold in plates. Clean all teh old urethane off the pinch weld in the window opening. Prime the pinch weld (not a paint, but an adhesive promoter). Place a bead of urethane around the pinch weld (about 1/4" thick bead). Place window in opening. Duct tape it so it stays. Go back inside and put any hold down strap back. Roll side windows down and slowly close doors. Wait 4 hours to dry.
Or just take it to a auto glass shop. May be easier and cheaper that way.
