a/c question 4.7 2001 quadcab
Old Oct 4, 2004 | 10:14 AM
quadman's Avatar
quadman
Default a/c question 4.7 2001 quadcab
is there a way to disable the a/c without,cutting wires or pulling the fuses which would also disable the fan, heater and the defrost? thanks in advance for any ideas.
Old Oct 8, 2004 | 11:37 AM
Kensai's Avatar
Kensai
Default RE: a/c question 4.7 2001 quadcab
ORIGINAL: quadman
Check the power harness that connects the A/C compressor under the hood to see if the harness can be disconnected or unplugged.
Old Dec 1, 2005 | 02:57 PM
sdsdsd's Avatar
sdsdsd
Unplug the compressor
Old Dec 1, 2005 | 05:23 PM
73roadrunner's Avatar
73roadrunner
Just a question but why would you want to disable the A/C ?
Old Dec 4, 2005 | 12:52 AM
vipes's Avatar
vipes
You might need that A/C in the winter to help defrost...
But if you are trying to save gas or something, I would take off the drive belt...
Old Dec 16, 2005 | 11:26 PM
titan2087's Avatar
titan2087
lol you could let all the refrigerant out of the system then it will cut off due to no gas.... course then youd get *** raped by the epa and would be a rather pain when you can just un do the wireing...
